Fenix 5X - 2.95 Beta Release
Hello Fenix 5X users,
We have new beta software ready for your upcoming adventures! Please read the 'notes' and 'installation instructions' in the 'Updates and Downloads' page found in the links below for your specific device. We look forward to your feedback.
Fenix 5X:http://www.garmin.com/support/download_details.jsp?id=11665
Please send all bug reports to [email][email protected][/email], and indicate which model of the fēnix 5 series you have in the subject line.
Note: Please allow for the updates to propagate across all servers. There is no need to post that the link does not work. It will after a bit of patience. :)
2.95 Change Log Notes:
  • Added support for Connect IQ SDK 2.3.
  • Added support for managing automatic software updates (Settings > System > Software Update > Auto Update). Setting Auto Update to “Off” will disable downloads of software updates using Garmin Connect Mobile and Wi-Fi.
  • Added support for managing unit settings for pressure, altimeter and temperature from corresponding widget settings menu.
  • Improved altimeter calibration for activities that were paused for extended periods of time.
  • Improved the layout of the alarm page.
  • Improved the activity settings menu by hiding GPS specific settings when GPS is turned off.
  • Improved the reliability of Livetrack.
  • Updated the summary view to include average Pace data for a pool swim activity.
  • Fixed a potential issue where the currently selected watchface may change after a software update.
  • Fixed an issue where the device could crash when applying a FaceIt watchface from the Garmin Connect Mobile App.
  • Fixed an issue where the ‘Uninstall’ option on the Garmin Connect Mobile App would not work as intended.
  • Fixed an issue, where the option to “Copy Activity” was present in the main menu for non-copyable apps like Golf.
  • Fixed an issue, where the unit would crash when creating a custom alert for a new ‘Other’ app.
  • Fixed an issue, where the virtual partner fields, ‘Time Ahead’ and ‘Time Behind’ won’t update during an activity.
  • Fixed an issue, where an empty elevation plot was being displayed during activity review for apps like, ‘Rowing’, which doesn’t record elevation data.
  • Fixed an issue, where alarms deleted on the Garmin Connect Mobile App would not reflect correctly on the device.
  • Fixed an issue, where the user would not get alert popups during a Lactate Threshold or FTP guided workout.
  • Fixed an issue, where GPS could become enabled for indoor profiles after performing an altimeter calibration.
  • Fixed an issue, where the device was calculating VO2 max for activities using Ultratrac.
  • Fixed an issue, where the ‘Do Not Disturb’ window was not updated when travelling across time zone boundaries.
  • Fixed an issue, where the user could not send tracks or waypoints to the device from Basecamp.
  • [Fenix 5X] Fixed a potential issue, where a Fenix5X device could crash while loading segments with names that had special characters.
  • [Fenix 5X] Fixed a potential issue, where saving a new round trip course could corrupt an existing round trip course on the device.
  • [Fenix 5X] Fixed an issue, where the ‘navigate’ app won’t start navigation, when picking a random location on the map.
  • [Fēnix 5X] Fixed a potential issue, where panning and zooming BirdsEye imagery on the map could crash the device.
  • [Fenix 5X] Fixed an issue, where one couldn’t rename a course on the device.
  • [Fenix 5X] Fixed a potential issue, where the watch could crash when generating a round trip course with the system language set to Czech.
Send all bug reports to [email][email protected][/email]
  • On 2.95.
    The following was tested last night:
    1. Backlight "watch" gesture set OFF.
    2. Note in-hours for automatic DND (sleeping); DND was ON.
    3. Backlight "in activity" gesture set to "after sunset"
    4. Start activity (running)
    5. Gesture DOES NOT work (no backlight), but when notifies (e.g. GPS lock, etc) come the light does come on.
    6. Exit activity, manually disable DND.
    7. Start activity (Running), gesture STILL does not function.
    8. Exit activity, set Gesture in-activity to "on" (not "After sunset)
    9. Start activity (Running), gesture STILL does not function.
    10. Exit activity, set WATCH gesture to "after sunset".
    11. Start activity (running), gesture now WORKS.
    It appears that the gesture setting for *watch mode* is being obeyed when in an activity, not the "in activity" setting.
  • The Garmin Cycle maps are no longer showing on my device? I updated the western Europe maps through express shortly after putting the beta on..
    Also the watch 'disconnected' during the map update so not sure if this broke it... the map .img file is still on the watch.
    Any ideas how to get the map back?!
    I an in Australia and seem to have lost the European maps and the US maps and only have pacific now.
  • I an in Australia and seem to have lost the European maps and the US maps and only have pacific now.
    This is seriously getting ridiculous! I have gone from not reliably been able to connect via USB, and now I can connect but 'all' maps have disappeared!!!
    This IMO is fast becoming worse than the F3.
    Not to be Captain Obvious, but there's a reason this is a Beta release.
  • Has anyone tried reverting to 2.9 and seeing if that brings the missing maps back?!
  • This is seriously getting ridiculous! I have gone from not reliably been able to connect via USB, and now I can connect but 'all' maps have disappeared!!!
    I'd suggest not getting too dramatic & remembering this only a beta. Try at your own risk and if you're willing to be an early adopter, bugs are to be expected.
    Kudos to the dev team for fixing this!
    Could you please consider adding an option to disable the optical heart rate sensor for certain activities (i. e. Mountainbiking). I either strap my watch to the handlebar or wear it over my jacket and don't want to turn the OHR off manually each time.
  • Battery Usage under 2.95
    I am getting poorer battery usage since 2.95. I am seeing about 14% drain per hour during an activity. I have previously seen around 8%.
    Anyone else seeing this? I don't think I have changed anything regarding backlight etc but if no one else is seeing it then I will look again
