Fénix 5x screen flickering
Is there anyone who has this little flicker on the screen? Is seen with any type of light (sunlight or indoor) and with the backlight off on the clock. it's a small flickering, but the screen of my fenix3 is completely fix compared with the screen of the fenix 5x
https://youtu.be/6nEAAOYDxdY
    guys, i have the issue too but seems to be less visible when Watch is fully charged. Same for you ?
  • Same problem here. Just started a new thread in affection before using the search function, sorry for that. I will send an email to my reseller asking for advices. Hard reset didn't solve my issue. I guess it is a hardware problem, but it would be interesting to see if all F5X are affected.
    As i told before "Today i have seen a friend of mine Fenix 5X's and it hasn't screen flickering issue! Serial number are more newer than mine (xxx43... vs xxx23...) and screen is a little more bright. So, i think this is an hardware issue!"
  • As i told before "Today i have seen a friend of mine Fenix 5X's and it hasn't screen flickering issue! Serial number are more newer than mine (xxx43... vs xxx23...) and screen is a little more bright. So, i think this is an hardware issue!"
    Alright, my SN is xxx42. Maybe the issue were solved in 43 and above then.
  • Alright, my SN is xxx42. Maybe the issue were solved in 43 and above then.
    I have a replacement on the way, maybe it will be here on Monday, i'll keep you updated!
  • I have a replacement on the way, maybe it will be here on Monday, i'll keep you updated!
    Thank you! Did you get a replacement from your reseller or through Garmin directly?
  • Thank you! Did you get a replacement from your reseller or through Garmin directly?
    From my reseller
    Mine is an "01" and I don't have his problem. Hopefully it's just a bad hardware batch?
    If it helps the "investigation".
    My SN is xxxxxx47 - no screen flickering visible
    duplicate -- forums acting weird. Takes a while to show up.
