Altimeter Fenix 5
This morning, as I always do, I drove 22 miles to work in the North west of England. According to several websites there is a difference in altitude between my start and finish points of circa 220 feet, the altimeter on my Fenix 5 shows no difference in altitude at any time in the last 4 hours. Is there a setting that I have wrong or is it a faulty unit?
I've had the watch less than a week so haven't noticed this before, so I don't know if this is the first occasion or whether or not the unit has been showing different altitudes previously.
Any assistance would be really appreciated.
  • Add my Garmin 5 to the list of crazy altimeters (it is an early build that I just purchased from Road Runner Sports (was probably on the shelf for 8 months). Otherwise it seems rock solid (GPS tracks are good, good battery life, fair Bluetooth and ANT+ connectivity - at least better than the Vivoactive 3 I had for about 2 weeks).
    I did check the Ambient pressure and it looks like it is responding mostly normally. It is very cold and dry right now ....
    Good day - I have emailed technical support, but thought I would weigh in on my new Garmin with problems. I have read this thread and found it to be useful regarding how the altimeter and barometer work together. I have had problems with elevation and believe my watch is not working. I added the ambient pressure to a new activity and when I check it shows 4765 mbar. I manually calibrated my altimeter and barometer to a close approximation of my location and using sea level pressure measurements from Environment Canada. However the number still make no sense. I do not know if the temperature is used at all for calculating the barometer value in the watch but I think that is my problem. It has fluctuated from -125 °C to 40 °C. I believe this is my problem because the barometer number has not changed since I manually calibrated but the apparent temperature has dropped by 10 ° and the altitude has dropped 100 meters (while sitting at my desk).
    Should I ask for a new watch from Garmin or wait for the tech support line to offer any other suggestions? I like the other features of this watch but it has been disappointing to jump into the GPS world of sport watches with this disappointment.
  • Today my Garmin Fenix 5 Altimeter, Barometer and Temperature sensors were spot-on. Counted floors correctly too (first time in a while). Not sure what was different from yesterday where they were going crazy except it got above freezing outside today ....
  • The reason that your barometric pressure is correct is that it is an artificial value which is decided by the watch. When the ambient pressure measurement decided to go off, the watch decided to stick to the last known barometric pressure. But the relationship between ambient pressure, altitude and barometric pressure has to be respected, so the watch also decided to change the altitude to something wildly off.
    The problem is your pressure sensor. It is defective. Or the air opening into the sensor is blocked. You should never, ever measure 862 millibar if you are only 100 meter above sea level.
    I think you are wrong with respect to HW vs SW error. I've returned my Fenix 5 saphire and got a new one that has worked very well up until today. I uploaded a couple of new watch faces. Looking into the altimeter log it seems that it immedately after the upload of the watch faces the altimeter (and barometer) started to go nuts. There was no reason for the sensor to get broken as I was sitting still in my office. I think that somehow the SW reading the sensor has gotten corrupt due the new watch faces.
  • There was no reason for the sensor to get broken as I was sitting still in my office.
    Give us some data!
    From your watch:
    • Barometric Pressure
    • Ambient Pressure
    • Altitude
    From the world around you:
    • Your real altitude.
    • The pressure from a weather station near you, either as a raw ambient pressure or an MSL corrected pressure.
    Then wait until the pressure at the weather station has changed 5-10 millibars and post the new readings from the watch and the weather station.
  • Then wait until the pressure at the weather station has changed 5-10 millibars and post the new readings from the watch and the weather station.
    I don't remember the data it showed exactly, but my office is at about 30MSL, it showed 998millibar(ambient pressure, same as my weather station) before the loading. Afterwards it showed MSL up and down in the range of -2xxxx to +1xxx. Unfortunately the watch has no log for the ambient pressure, but the log for the barometer shows that it has been down to 732 and up to 1002millibar. As far as I can remember the ambient pressure showed 850 something at the most extreme.
    I've now removed all the watch faces, and I'm keeping my fingers crossed that it will normalize again. I'm quite optimistic as it now shows: 989 ambient, 998baro and 105MSL. I'm currently at 105MSL and the external barometer shows 1001millibar.
  • Please keep posting. This is really interesting. If it turns out that you can affect the ambient pressure reading by installing and uninstalling watch faces, it might explain why some users have had the same problems on several watches.
    I can't remember if it was already posted in this thread, but some F5 users have found out that static electricity from their clothing could affect the pressure reading. So you should be careful with that while testing.
  • Maybe the relative humidity around the sensor plays a role in the erroneous readings. I am thinking that very low relative humidity might be causing a problem (would also correspond to the static electricity from clothing affecting things. Today my readings were again all over the place in auto mode - switching to altimeter mode keeps it more reasonable .... I was getting storm alerts inside our building (the air temp is 10 F outside with a very dry airmass in place right now after the coastal bomb storm.
    Yes switching to Altimeter mode in my case seems to be fine. The Auto mode in my opinion seems buggy. My understanding reading a bunch of threads is that in Auto mode the watch tries to detect when the ambient pressure variations are due to changes in elevation or weather related.
    As a side note thanks AllanOlsen67 for meteo terminology explanations.
    I'm worried that Garmin does not seem to address this issue. There are reddit and forum threads reporting similar issue back to F3.
  • Yes switching to Altimeter mode in my case seems to be fine. The Auto mode in my opinion seems buggy.
    Altimeter Mode is only fine as long as the surrounding pressure at unchanged altitude doesn't change. So in the long term (over more than very few hours), Altimeter Mode will be of no use unless you calibrate the altimeter all the time.
    The Auto Mode can only be considered buggy if we see it making choices which would never make sense in that situation.
    Just making the wrong guess based on a sound decision algorithm is not enough to consider the Auto Mode buggy. There will be plenty of those wrong guesses because the watch has insufficient information to always make the correct choice. In fact, I think that the biggest problem is users unable to understand this.
