So it begins.
I will have mine Fenix 5 on Saturday and will start doing comparisons to an Ambit 3 Peak. I don't have an F3 to directly compare to as of now.
Anyone have an F3 and F5 to compare?
The GPS + GLONASS doesn't improve accuracy, it only helps you get a quicker GPS acquisition and hold on to a satellite lock when there is a limited view of the sky. The watches only calculate position from the signals of three satellites and there are 12 GPS and 12 GLONASS satellites in each hemisphere.
The tracks on your map with GPS and GPS + GLONASS show that you are using Smart Data Recording. To improve your accuracy, you should change that setting to Every Second.
the GPS chip Mediatek is the same of Fenix 3 ?
I'm doing a weekend hike this weekend in the Adirondack high peaks. This will be the first real hiking test for my F5. I'll post back with results.
That's rough. Do you have any good tracks, or are they all equally bad?
