So it begins.
I will have mine Fenix 5 on Saturday and will start doing comparisons to an Ambit 3 Peak. I don't have an F3 to directly compare to as of now.
Anyone have an F3 and F5 to compare?
Well, I hate to bump this thread back to the top when it already hit page 2, but I think this should be looked at.
I walked around a small lake today with some open areas around it, so I thought why not test out the accuracy of Ultra Track. I loaded the walking app on my watch, set GPS to Ultra Track and started to walk. About a third of the way I saw a dead fish in the lake which I wanted to get a closer look at so I paused the activity, spent about two minutes at that spot and then continued the activity all the way around the lake. Let's take a look at the activity:
https://connect.garmin.com/modern/activity/1635876998
As you can see, for some reason the GPS stopped right where I paused the activity and didn't pick up when I continued. What is even more astounding (apart from the rather spotty track; the beginning is spot on but I never left the path next to the lake) is that in Connect it says that the walk was 1.65km long, but when you load the track into mygpsfiles or Google Earth you can see that it is really only 0.5km long and stops where I paused it. Did Connect simply auto-guess the pace for the rest of the activity since it was still running but GPS stopped? And why did the GPS not continue tracking? I'll try tomorrow if the GPS not continuing is a bug in the walking app when you pause it.
What do you guys think?
Just tried the walking app again in my neighbourhood on a short 10min walk and can reproduce the same bug as yesterday - the distance seems somewhat accurate in Garmin Connect but the track stops exactly where I paused the activity about halfway through. Can anybody else reproduce and confirm this bug? Auto-Pause was disabled and GPS was set to Ultra-Track.
Any reason why you are using ultra-track for a short walk? I would report the bug to Garmin, but I'd also turn on normal GPS +/- GLONASS and see if the bug persists.
So I've just done a quick walk around the block using the Hike app set to UltraTrac (so won't be a perfectly pretty track - in case anyone wants to leap to some GPS inaccuracy conclusion). In the picture below the blue arrow is the point at which I stopped, hit the start/stop button, selected resume later, waited a few seconds with the F5 in normal watch mode, hit the Start button, waited for the green GPS lock ring to appear, and then selected the Resume option. You can see the track carried on recording fine. The only thing I can think is if you are not waiting for the GPS lock green ring to appear before trying to resume.
