So it begins.
I will have mine Fenix 5 on Saturday and will start doing comparisons to an Ambit 3 Peak. I don't have an F3 to directly compare to as of now.
Anyone have an F3 and F5 to compare?
1% is very solid. There are so many nuances as to why a given unit might measure 1% difference, that you'd actually have to dive into every track and see why one is higher than the other. Without doing that, then saying one is right and the other is wrong is no different than doing the opposite.
As a general rule, I try not to use any comparisons with less than three devices. If less than three devices, then I'd stick purely to looking at tracks (never in map mode, always in satellite mode), and then reference that with what my brain says I actually ran.
Also, you'd want to validate both are using 1-second recording, both are using the same GPS/GLONASS settings, and neither are being blocked by the other (i.e. I try to never test on same wrist).
I would say it's different for everyone. Speaking as a mountain trail runner, GPS accuracy is definitely what I'm paying for when I buy a high-end GPS watch. I can go several months and sometimes years between my visits to certain trails/trail races, and I use my tracks to re-orientate myself. Most trails and trail race courses present their own unique challenges and hazards. My GPS tracks (and the pace/HR data connected to them) are my record of an adventure and a learning tool for future races. I'm not trying to go on a diatribe, just pointing out that spotty GPS will destroy your tracks on a trail run with lots switch-backs and elevation changes. It sounds like people are having more success on successive runs so it's not really an issue anyways. I've always trusted Garmin to improve their hardware and software.
All good points and that's what's been done here, see the previous posts, bar the third device, but with only two arms it gets tricky not to have one blocked if you do that. Maybe an extra long strap to put it high up on the forerarm ?
Again 1% doesn't sound like a lot except if you've memorized your M pace and on race day you have the choice between :
A. your HR is higher at the same "mile marker" pace -> recipe for disaster
B. you slow down by 3"/km and miss your goal
I'm looking forward to seeing what happens on the track to work with a known distance.
Depending on GPS only for pacing is a recipe for disaster in any race. Best bet is to reset your watch with the lap button if you notice your auto-lap drifting off, or better yet turn off auto-lap and hit the mile markers (though sometimes the mile markers can be off too)
Obviously (and there are even CIQ/DFs that can auto-correct the distance and time ahead/behind) but you're missing the point, if you've trained for weeks at 4'30"/km on the open roads with your F5 and that translates to 4'33"/km during the race using actual/"mile marker" pace you have the two options I mentioned above, neither satisfactory.
GPS vs GPS+GLONASS?
I saw some weird behaviour this morning- I ran on the exact same path through the park this morning during both laps (every second recording on a 5X)
https://connect.garmin.com/modern/activity/1631869175
