Fenix 5S/5 Plus - 5.53 Beta Release
Hello Fenix 5/5S Plus users,
We have new beta software ready for your upcoming adventures!
Fenix 5S Plus: https://www8.garmin.com/support/down...s.jsp?id=14333
Fenix 5 Plus: https://www8.garmin.com/support/download_details.jsp?id=14331
Note: Please allow for the updates to propagate across all servers. There is no need to post that the link does not work. It will after a bit of patience.
5.53 Change Log Notes:
  • Fixed an issue introduced in version 5.52 Beta that could cause high battery drain
Please note, the beta updates released on these forums are not suitable for APAC region devices.
Please send all bug reports to [EMAIL="[email protected]"][email protected][/EMAIL], and indicate which model of the fenix 5 Plus series you have in the subject line.
  • I use screen default.. nothing more.... :(
    Well, today i had 2 issues:
    (using 5.53, GPS only)
    1_ Look at the starting point, really weird deviation, i waited like 30 minutes for GPS fix (it was a 10k popular race); start and end point were the same, btw.
    2_ Have a lot of problems pairing BT headphones so (20 mins before the start) i unpaired and paired again, tried music and was working fine, when the race started the green cyrcle of the song was moving but i didn't hear anything, did "next" to other song and same, it acted like it was playing but no sound (volume was ok), so all the race without music. After the race i turn off the watch, turn on and music was playing fine. It's like the waiting of 20mins in pause mode screwup the thing.
    https://ibb.co/btJ2Y0
  • Yesterday I transfered some Strava segments to the F5+ and went for a long trail run. I confirm that they don’t work. They are into the segment list but I had no notification of approaching, timing etc. My activity settings are correct:
    Segment Alerts ON
    Auto Effort ON
  • ....Strava segments to the F5+ and went for a long trail run. I confirm that they don’t work.
    I wonder why things are not working for you. On a 6 mile run yesterday and bike ride in to work today, Strava segments were working just fine on my 5+ on sw 5.53. I do tend to sync frequently with Express via USB, which regularly updates the Strava segment data on the 5+. Are you only syncing segments via GCM?
  • I wonder why things are not working for you. On a 6 mile run yesterday and bike ride in to work today, Strava segments were working just fine on my 5+ on sw 5.53. I do tend to sync frequently with Express via USB, which regularly updates the Strava segment data on the 5+. Are you only syncing segments via GCM?
    I did the sync through GCM and the segments transfered to the F5+ correctly. They appear in the Strava Segments list. I remember that this featured was ok some weeks ago. The activity I used yesterday, had 8 data screens ands I had the course navigation enabled as I was on an unfamiliar path. Maybe segments are not working properly when navigation is enabled. I don’t know, I have to do some tests.
  • I had the course navigation enabled as I was on an unfamiliar path. Maybe segments are not working properly when navigation is enabled.
    Ah, that explains things. From my experience Strava Segmemts don’t work whilst you are navigating a course or route (calculated by the watch from the routeable internal map), the segments also won’t work when you are executing a Workout or doing the LTHR Test routine.
  • Ah, that explains things. From my experience Strava Segmemts don’t work whilst you are navigating a course or route (calculated by the watch from the routeable internal map), the segments also won’t work when you are executing a Workout or doing the LTHR Test routine.
    So it makes sense...false alarm! ????
    Multiple issues lately with Fenix 5s plus (all came after downloading 5.53 beta):
    1. Floors climbed errors
    Today, I went on a 6 mi run on a very flat path (around 80 ft climbed for the whole run) and the watch said I climbed 15 flights of stairs! Prior to the run I had 0 flights climbed, so I know it was all generated from this run. Also I have run this same route many many times and prior software versions have measured 0-3 flights (definitely has been variable in the past but never this bad).
    Had a similar situation on a walk yesterday. About 4.25 mi, again a route I have done many times, and would expect 3-4 flights from but watch said 16.
    2. Battery issues
    In general, battery drainage seemed a little better initially. But then I had a new issue today. After several activities, I charged the watch to 91%. When I took it off the charger, a different stock watch face was on. And then it drained to 83% over 15 minutes! There was nothing different about the charger I used or anything else.
    3. Memory full message
    Over the weekend I had a message pop up that the watch's memory was getting low and I needed to sync activities to Garmin connect. Well I always sync automatically to garmin connect via wifi or bluetooth after an activity, so all my activities had been saved except for the one that had just been completed. I was away from home, so could not check files on my computer, so I deleted a few activities. I was able to do more activities without the message popping up again. When I got home and connected my watch to the computer, it said I had 8 MB free, so I am confused about why that message came up in the first place. I have owned several other garmin watches for a much longer period of time and have never seen this message before either.
  • virtual partner is still not working. but i am sure you will fix some music stuff in the next beta
  • I understand your frustration regarding virtual partner and you are of course allowed to think that music is just a silly gimmick thing, but has it occured to you that other people may care about the music stuff?
    I don’t understand why you need to put those two features up against each other.
