Map Vehcile icon doesn not change
using montana 700i, software version 16.50 with latest maps / firmware
I cannot change the vehicle icon. It always stays the same.
Steps to reproduce:
home / setup / Map / Advanced setup / Vehicle
does any one know how to fix this ?
  • And I suggest you stop being so incredibly stubborn when someone reports a problem, giving overwhelming evidence. This also applies to other problems I have reported here on the forum that you have responded to. Fine if you're trying to help someone, but take it seriously when someone reports a problem! The bug is simply that the 3D arrow icon is different per profile while all others work fine. So first just try things out ,read the post carefully,  and stop acting like others are morons.
  • I cannot change the vehicle icon. It always stays the same.
    The overwhelming evidence you shared shows you selecting the same vehicle icon that was already displayed.  Of course it did not change. You indicated you wanted a specific icon and I shared with you exactly how to select it.
    You are correct, the evidence here is overwhelming...
