Is the inReach Sent Confirmation - just unit sending or also satellite receive confirmation?
  1. Is the inReach Sent Confirmation (chirp) only confirmation the unit sent the message OR is it also confirmation the *satellite* successfully received it. If so, that would require the satellite to send a receive confirmation back to the unit. Anyone know?
  • Any message exchange with the Iridium network is acknowledged. Can't vouch for the chirp. But if the unit says the message was sent, then the Iridium network acknowledged it. But this is only the satellite overhead. Iridium relays through a mesh network of satellites until it reaches one over a ground station. Then it goes to the ground station, and on to the Garmin servers. From there, it'll go to an email provider or to an SMS gateway.
    Bottom line: Lots of moving parts. The acknowledgement is not end to end. The only thing the "sent status" on the unit is good for is tell you that you don't need to continue to look for a good sky view in order to do the send.
  • Thank you for your reply. I could not find the answer after a lot of searching and appreciate your insight. I had a SPOT unit and there is no handshake with the satellite with their system. inReach seems much better.
