Mal Datums
Hello
I use a Garmin 66ST.  I am having difficulty working out map datums.
if I mark a location using the GPS with the map datum set to WGS84, and then use a paper map that has a datum of 66, will the waypoint I previously marked be displayed at the correct location (assuming I set the map datum to 66 to correspond to the paper map in use)?
Thanks
