Since installing CT1 Trackers. I have regular S70 freezing during the round. Never had that in 18 months of use.
Some times it un freezes after a couple of holes (15 mins) but some times i have to restart Any ideas?
I am having the same problem. All map shots get deleted after freeze up, but score is still there.
Has this been addressed? I’m seeing freezing with s70 paired with the ct1. Waiting to purchase depending if this is fixed or not
I'm so fed up with this problem. The watch will either reboot or just freeze 2-3 times per round. When it freezes you need to do a hard reset to get it running again. Sometimes it will reboot even when not playing golf, it can happen when the watch is just lying on the table beside me.
Tried disconnecting the CT1 sensors from the watch but the problem persists.
Today I returned the sensors and the watch to the dealership, they will run some diagnostics and get back to me but I think it's faulty. Not taking that one back!
I’m fed up with this too. I can’t believe Garmin can’t make a watch that doesn’t crash.
Hello
I have exactly the same problem.
Each time i'm using the CT1, i have the problem beetween 1 or 3 times on a 9 holes.
So i can't use it when i'm playing on a competition, due to the risk to loose my score.
I'm using 10 CT-1
Do you think if im' usng less CT1 the problem will disapear ?
PS : sorry for my bad english !
Thks
Nonodup
I have reached out to you via direct message to gather some additional information from you on this concern.
Keep an eye out for my direct message requesting some additional info through the message icon in the upper right section of forums.
