GC nicht erreichbar
Seit gestern funktioniert der Server von GC nicht mehr, auch die Satus Seite ist nicht erreichbar :-(
A PHP Error was encountered
Severity: Warning
Message: file_get_contents(http://static.garmin.com/com.garmin.connect-config/config/com.garmin.connect-v1.0.0.json): failed to open stream: HTTP request failed!
Filename: lib/api_base.php
Line Number: 327
Invalid configuration: empty json
Internal Error
Sorry, we encountered an internal error.
Details
500 Internal Server Error
org.springframework.web.client.DefaultResponseErrorHandler.handleError(DefaultResponseErrorHandler.java:91)
org.springframework.web.client.RestTemplate.handleResponseError(RestTemplate.java:533)
org.springframework.web.client.RestTemplate.doExecute(RestTemplate.java:489)
org.springframework.web.client.RestTemplate.execute(RestTemplate.java:447)
org.springframework.web.client.RestTemplate.getForObject(RestTemplate.java:215)
com.garmin.connect.oauth.impl.DefaultOauthRestClientImpl.get(DefaultOauthRestClientImpl.java:60)
com.garmin.web.DashboardController.populateLoggedInModel(DashboardController.java:685)
com.garmin.web.DashboardController.populateDefaultModel(DashboardController.java:622)
com.garmin.web.DashboardController.dashboard(DashboardController.java:142)
sun.reflect.GeneratedMethodAccessor55.invoke(Unknown Source)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
java.lang.reflect.Method.invoke(Method.java:606)
org.springframework.web.method.support.InvocableHandlerMethod.invoke(InvocableHandlerMethod.java:219)
org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:132)
org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:104)
org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandleMethod(RequestMappingHandlerAdapter.java:746)
org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:687)
org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:80)
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:925)
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:856)
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:915)
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:811)
javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:796)
javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
com.garmin.web.service.util.XHttpMethodOverrideFilter.doFilterInternal(XHttpMethodOverrideFilter.java:62)
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
com.garmin.web.filter.sso.AuthenticationFilter.doFilter(AuthenticationFilter.java:161)
com.garmin.web.filter.sso.ConditionalFilterChain.doFilter(ConditionalFilterChain.java:44)
org.jasig.cas.client.util.AssertionThreadLocalFilter.doFilter(AssertionThreadLocalFilter.java:63)
com.garmin.web.filter.sso.ConditionalFilterChain.doFilter(ConditionalFilterChain.java:41)
org.jasig.cas.client.util.HttpServletRequestWrapperFilter.doFilter(HttpServletRequestWrapperFilter.java:86)
com.garmin.security.cas.client.validation.AbstractTicketValidationFilter.doFilter(AbstractTicketValidationFilter.java:389)
com.garmin.security.cas.client.authentication.UnprotectedAuthenticationFilter.doFilter(UnprotectedAuthenticationFilter.java:98)
com.garmin.security.cas.client.session.SingleSignOutFilter.doFilter(SingleSignOutFilter.java:92)
com.garmin.security.cas.client.util.ExcludedURLDetectionFilter.doFilter(ExcludedURLDetectionFilter.java:68)
com.garmin.web.filter.sso.ConditionalFilter.doFilter(ConditionalFilter.java:81)
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:224)
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:169)
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
org.apache.coyote.ajp.AjpAprProcessor.process(AjpAprProcessor.java:197)
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:579)
org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:1805)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
java.lang.Thread.run(Thread.java:745)
Severity: Warning
Line Number: 327
  • Man kann dies leider auch anders sehen, alle Daten sind auf den Servern weg, das Backup defekt. Wieso bietet der Hersteller den Kunden nicht wie früher
    Programme an die man lokal installiert und die Daten dazu zusätzlich speichert. Nein heutzutage muss alles auf Servern irgendwo in der Welt abgelegt
    werden.
    Gruß Stefan
    Für einen winzigen, winzigen Betrag speichert Tapiriik meine Läufe kurz nach dem Hochladen bei Garmin automatisch in meiner Dropbox. Alle Daten der letzten 8 Jahre sind selbst bei einem Totalverlust bei Garmin bei mir vorhanden.
  • ...., alle Daten sind auf den Servern weg, ....... Nein heutzutage muss alles auf Servern irgendwo in der Welt abgelegt
    werden.
    Gruß Stefan
    Verstehe ich nicht so ganz, die Trainings sind doch alle nochmals lokal auf dem Rechner gespeichert und damit nicht verloren. Ob der Server nun abschmiert oder nicht.
    Gruß
    Dirk
  • Verstehe ich nicht so ganz, die Trainings sind doch alle nochmals lokal auf dem Rechner gespeichert und damit nicht verloren. Ob der Server nun abschmiert oder nicht.
    Gruß
    Dirk
    Hallo Dirk,
    wo sind diese gespeichert, ich nutze einen Mac und hier habe ich noch Basecamp um Wandertouren zu planen, dann nutze ich noch ein Programm eines anderen abieters, aber die Daten direkt in ein Garmin Programm habe ich nicht. TC von Garmin wurde ja eingestellt.
    Gruß Stefan
  • Hallo Dirk,
    Gruß Stefan
    Ah, die Mac Fraktion. Hast Du Express installiert? Bei mir sind alle *.fit Dateien nochmals lokal gespeichert und ich importiere die immer in Runalyze. Wo die beim Mac liegen (könnten) kann ich Dir nicht sagen.
    Gruß
    Dirk
