To install this beta, you will need to be enrolled in the beta program, and have added a wifi network. Information on this can be found here.
With a wifi network added to you. Edge, navigate to the Main Menu > select System > select About > select Check For Updates.
It may be necessary to then scroll up and select Software Update 31.20 to install this after downloading.
Note to users: If you see "Collecting diagnostics..." go to Menu > System > Diagnostics > Upload RAM Dump.
Change Log 31.20
- Fixed crash using RTS to edit data screens.
- Fixed crash on course list.
- Fixed step goal being changed unexpectedly.
- Fixed CIQ data fields causing UI lag/freeze.
- Fixed options menu while start/stop/pause overlay is present.
- Fixed elevation profile manual scale adjustments.
- Fixed dew point and UV-index in weather widget.
Change Log 31.18
- Fixed translation issue causing "Day" to be added to date strings.
Change Log 31.15
- Added support for gear tracking improvements.
- Updated radar data screen to support the selected Color Mode instead of always displaying in dark mode.
- Fixed some flat roads giving credit for climbs.
- Fixed auto zoom while following a course.
- Fixed Strava widget freezing on some devices.
- Fixed ClimbPro page not showing grade/position correctly.
- Fixed time in gear for shifters not showing in ride summary.
- Fixed time in gear for Shimano eBike shifters.
- Fixed crash during course navigation.
- Fixed crash while searching for recent finds.
- General improvements to device stability and addressed various minor bugs
