requesting device identification file failed on fenix 2 first time bluetooth use
I am getting this error while attempting to connect my garmin fenix 2 via bluetooth to my phone.
I installed the gamin connect app on my android phone.
I turned on bluetooth on my fenix 2, and tried to do the pairing, entered the key, and step one worked (smiley face) step 2 failed with this error
"requesting device identification file failed"
i googled and there is ZERO help for this situation listed on the web for fenix 2.
    I ended up downgrading my Fenix 3 to 4.20 (which factory resets the device too though). Then paired to my phone perfectly and then upgraded to 4.40. I can now pair to new devices with no problems anymore :)
  • Also have this issue now.
    All was fine yesterday afternoon, then in the evening my text messages stopped coming through on the Fenix3
    I tried to disconnect the Fenix3 and pair again with HTC One M8, and now I keep getting stuck at ":( requesting device identification file failed"
    Mine seemed to fix itself overnight, all was working fine yesterday
  • Same issue
    Fenix 3 with Samsung Galaxy S6. Requesting device id file failed.
    Gotta be something with the server end. My steps also won't update today.
    I have the same issue. :(
    Are there any solution?
    Thanks
  • Mine did it again yesterday evening, after working fine during the day
    And today it's working again!
    I think it's a Garmin Connect issue rather than the watch
    Thanks
    Downgrading the firmware to 4.20 and then upgrading again fixed the problem for me...
    Solution for me
    on Fenix 3, I had also the same issue (firmware 4.40)
    Solution, during pairing while step "requesting device identification file...", I go back to the watch and select "Sync" in the bluetouth menu. The pairing finnally ended succesfully.
    BR
    tesca
    BR
    tesca
    Wow, wish I had tried this before the downgrade/upgrade process :eek:
    me too :(. nice to know this works for you too.
  • I've been having this same problem with fully pairing my Fenix 3 to my phone. I first found the problem when I loaded a new ROM on the phone and had to reconnect to Garmin Connect. It kept getting stuck on the "requesting device identification." I even tried to hit "sync" when it got to that portion but that didn't help any. The first time, I wiped out the watch and started back up from scratch. That worked until I had to connect again after I switched ROM's again. I know, I have a problem, haha.
    I didn't want to have to wipe out the watch again and have to go through all the settings to get it how I like it so I tried something different. What ended up working was going into Garmin Express and deleting the watch from there. Then I went to connect.garmin.com and deleted the phone out of there. Once I did all that, it sync'd just fine. Hopefully that helps someone with this problem.
  • on Fenix 3, I had also the same issue (firmware 4.40)
    BR
    tesca
    This appears to have worked for me too (so far). Thank you :)
