Corrupt .FIT File? 920XT
Hi Guys, I have just started using a new 920XT and initially it was syncing with Garmin Connect but then I started continually getting a sync error.
After reading other post I worked out I had a corrupt .fit file. I ended removing the corrupt file form my device and everything is now working again correctly.
I am now trying to repair the corrupt file. I have tried using the Autofix function on http://garmin.kiesewetter.nl/ . This goes thru the process and creates the "fixed" file, however I still cannot upload it, I get an error as shown in the attached screen shot.
I have also attached my original .fit file. I am hoping someone may be able to have a look at it for ma and tell me what the problem may be or fix it for me?
Any help would be appreciated, thanks guys...
    can some one fix mine please? First time this has happened and happened after the recent upgrade to 3.3 sw....
    Hello Richard,
    The file looks perfect, no lost data.
    The Tool gave a warning that the corruption was from abruptly shutting down and losing the closing headers but of course you were already finished.
    The battery condition for the power meter shows good, the HRM shows very poor, the 920 shows no battery data.
    The software version shows up as 320 not 330??
    So....here ya go. Fixed with the Fit File Repair Tool.
    https://www.dropbox.com/s/tsp48q7jh1wfwur/54PA3632-fixed.fit?dl=0
    Can someone help me fix this corrupt file from my 920? It uploads to Training Peaks but not to GC. Any help would be greatly appreciated.
    Hello Ellie,
    The data starts abruptly with you moving at 8mph and then stops abruptly 13 miles later with you still moving at 9mph.
    Looking at the map it appears that you are missing data from the beginning and the end of your run.
    There are no battery values listed.
    The 920 software is listed as version 257??
    So....here ya go. Fixed what was there with the Fit File Repair Tool.
    https://www.dropbox.com/s/8j4gelz1lr8wwao/51P71946-fixed.fit?dl=0
