How to Edit or Delete Golf Score Cards
I've got a few errors on my Garmin Connect now after using my Approach 4S a few times. I just can't see how to edit or delete rounds which makes Connect utterly pointless.
I'm having to still use Shotzoom which is good but does nothing extra to Connect apart from being able to edit/delete.
Storing scorecards on the watch is not helpful.
    Just deleted scorecards
    Go to My Garmin
    Go to Extra's (at least this is the name on the Dutch site, it has the scorecards)
    Go to Garmin Connect
    On the scorecards display hit the radar wheel top right corner
    Change to "list" display
    Click on the course you want to delete
    On the course displayed you will find a little dustbin top right hand corner
    When I had removed all faulty courses my statitics became based only on the remaining courses.
    Edit score
    I appreciate this is a late reply to the original post however I had the same issue when trying to edit a scorecard when I failed to record a score for a hole and only just noticed. After a bit of faffing around I found out you can simply edit the scorecard xml file using Notepad, the xml files are stored in the scorecard folder which you can see if you explore the storage via My Computer. You have to make sure you enter the score twice as per the below example:
    <PlayerHole> <HoleNumber>12</HoleNumber> <HoleScore>3</HoleScore> <HoleStrokeScore>3</HoleStrokeScore></PlayerHole>
    Hope this helps.
    Dan
    Dan's right
    Well done Dan. Tried it, hit sync and it cleaned up the card.
    Thank you
    Jake
    Edit score card
    As with many others, where does one edit a score card. I missed 2 holes out of 18 and I can't add them. Very frustrating.
    edit card in garmin connect
    Hello,
    Do you know if garmin plan to implement the edition of the scorecard in garmin connect?
    Thanks
    Editing last score of golf round on Approach S3
    I found this on the Garmin website. after searching on how to edit a round of golf, I finally figured out that you can only edit the last round of golf played with my Approach S3 watch. Here are the directions from the Garmin website.
    "The Approach S3, S4, S5, and S6 allow you to edit the scorecard from your most recent round. These can only be edited until a new round has begun.
    To edit a scorecard:
    Power on and unlock Approach
    Press Score
    Scroll through round and select hole to edit
    Press the "-" and "+" symbols to change score
    Press the back arrow twice - "Saving Scorecard" should then appear on the screen, indicating changes are saved."
    At least I can edit my last round of golf. Still trying to see if there is any way to edit my prior rounds. I've forgotten to add a couple of holes and want to keep my stats accurate.
    Edit golf scorecard
    Press Score
    So bottom line is that we can't edit golf scorecard on vivoactive? If this changes will someone tell me how to do it. Thanks
    Edit Scorecard
    So it the bottom line that we can't edit scorecards on the vivoactive Golf app? Hopefully this is changed soon.
    Edit scorecards
    The best way is to check each hole on your scorecard before saving the round. I keep an official scorecard and check Vivoactive against this before saving the round. Works every time!
    File Name
    Hope this helps.
    Dan
    Dan,
    What is the file name , I cannot find it under Garmin Express
