A solution for combining/merging two TCX files (activies)
This weekend I needed to adjust my interval workout while it was in progress (yes, I needed a break!) This resulted in me having two different activities and two TCX files for each.
I searched and downloaded various software, but they didn't do exactly what I wanted. (Some didn't preserve the calories, and some turned the workout into a course, etc)
I then tried just copying all the laps from one TCX to the other using notepad, but that didn't work either. The distance was corrupt when I uploaded to Garmin Connect. I realized that the the individual laps in each activity have a cumulative distance tracker. So all I needed to do to make this work is offset the last distance tracked to all of the distances from the other activity.
I created a simple XSLT transform that can be applied to two TCX files and it will create a new merged activity.
Thought I'd share.
(Note, you'll need a XSLT processor like saxon/xalan or others)
    0 Former Member over 11 years ago
    Hi there, first time posting.
    I did my first half ironman on the weekend. After lecturing my friends on the correct buttons to push during transition, went and stuffed up mine.
    So now I have a 61km swim :)
    I have tried the java program that was linked to earlier but can't seem to get it to work.
    Does anyone have any suggestions on what else I can try, as I would really like to try and tidy it all up.
    Thanks.
    Hello David,
    Attach a copy of the original fit file to another post here and someone will try to fix it.
    Thank you.
    Here are the files, one is the swim and ride, one is the transition when I worked out that I had stuffed up and the last is the finish of my ride.
    If someone can sort these out I will be eternally grateful.
    Thanks in advance.
    David.
    Have managed to exceed the max. file size.
    Will try again later.
    get yourself a free dropbox account and upload and then share the link to the files in a reply message.
    cheers
    Mike
    hi David,
    have downloaded your tcx files no problems and they load happily into the Fit File Repair Tool.
    I can see that the first file contains your swim and your bike?
    The second file contains 1 set of data values and I would hazard a guess can be disregarded.
    The third file is a continuation of your bike? Or is it your run leg? Reason I ask is that if it's your run leg you were getting along at a VERY good pace (between 25 and 27kph)
    Now I am have missed it, but what is it that you are trying to do with these files? Do you want your swim in a separate tcx file and then the remainder (which is your bike?) combined into one file? OR do you just want the all three files combined?
    cheers
    Mike
    Hi Mike,
    Thanks for having a look at my stuff up :)
    The first file, ending in 94, is the swim leg, which ended at about 36min 40 or so, and the first 60km or so of the ride. I pressed stop at the end of the swim instead of pause, then restarted at the start of the bike leg.
    The file ending in 97, is where I worked out my mistake and did a very quick transition, so can probably be disregarded.
    The final file is the remainder of the ride.
    I was hoping to separate the swim and the ride into 2 separate files.
    Thanks again for having a look.
    David
    Hi Dave,
    'Think' I have got it nailed so check out these two files - swim and bike.
    Let me know if there are any issues and I will give it another shot.
    cheers
    Mike
    Mike you are a champion,
    Thank you very much.
    Worked like a charm.
    Thanks again,
    David. :D
