bug in dakota 20 firmware 2.80 ?
Where can i report a bug? I have just update my dakota 20 to v.2.80. Now i have problem save my track. The device is just turning itself off.
I did not have this problem with 2.70 :confused:
tested eneloop charge battery and normal battery you buy in the store, same problem. So it´s not the power
A.Espedal
    Save TRACK
    after update of the firmware to 2.90 the bug is still there. I can not save the tracklog.
    YES!!!
    the problem was resolved with version 2.90 of firmaware
    a dedicated outdoor GPS does not save the tracks??:mad::mad::mad::mad:
    I tried 2.90, tested with saveing track. Turned off :mad:
    Downgrade to 2.70 again.
    2 firmware update , an still the same problem. wake up garmin :confused:
    Yeah. Wake up Garmin.
    2.90 will work fine if you do a reset
    hear is how to do a reset, hold down on the top left of the screen when your turning on , till you see the the do you really want to erase all user data screen click yes . your tracks should save now with no problems ;)
    same problem
    Hi everybody , I have the same problem with the software version 2.90
    BOABNESS your suggestion didnt work.......sorry.......
    hi mate your right it worked for me then it stops working.
    then i found out if you change the colour of the track then save, this would work
    now its not working again so it still crashes the gps when you try to save a track :mad:
    Yesterday I reported this situation to Garmin , I´m waiting for an answer....if I have news I´LL inform all of you.
    Hahaha, I thought my GPS was the problem. Bad for Garmin, I think maybe I will return this Dakota and back to my trusty and loyal Edge 305.
    :mad:
    :mad:
    :mad:
    I will wait any answer from Support.
    :mad:
    There´s the solution !!! As ussualy the technical support of Garmin are efficient.
    So you must connect the dakota to your PC then go to folder garmin and there you must delete the folder GPX.
    Disconect your Dakota restart and there´s the solution. It works in my device.
