Add support for a Withings wifi scale
Instead of me manually entering my weight & body fat, how about having some integration with the Withings wifi scale?
Here's the API link
http://www.withings.com/en/api/bodyscale
    Hi,
    I use syncmetrics.com to sync from Garmin to Runkeeper. For Withings, datas are well imported in syncmetrics , but data aren't sending to Garmin (I have check "Sync Withings Weight to Garmin"). Any solution to fix that ?
    Hi LLAUMGUI,
    Mine is working. Login to sync metrics. Click on your profile in the top right corner, click on sync settings, click on Withings, and make sure the "Sync Withings Weight to Garmin" is ticked. If you've already done that, try unpicking it, saving it, and then re ticking it again and saving it again.
  • If you've already done that, try unpicking it, saving it, and then re ticking it again and saving it again.
    Thank a lot for your help... But I have already do that... There is no sync log in syncmetrics.com ?
    Have you set it up in your Withings account to have access to sync metrics yet?
    https://healthmate.withings.com/partners
  • Have you set it up in your Withings account to have access to sync metrics yet?
    Yes. My Withings datas are imported on Syncmetrics
  • I have the exact same problem, must be a bug. :(
  • Was bummed that my new Edge 1000 could not communicate with my Withings Smart Body analyzer which features both WIFI and Bluetooth, same as the 1000.
    Please add support for it soon Garmin!
  • Was just about to sign up to SyncMetrics as it sounds useful.....on their web page :(
    We’d like to thank everyone for the support we received over the last two years. We have worked hard on SyncMetrics but at the moment we will not be able to keep the service running.
    We are still trying to find ways to get SyncMetrics back online and will keep you posted through this page on any progress.
    Thanks you!
    +1 for the withings support
    Hi
    I also used syncmetrics to sync between Withings and GC, unfortunately it looks like syncmetrics will be history (down since weeks) :-(
    Now, as Garmin has introduced some official ways to sync between different other plattforms (eg myfitnesspal), I use a workaround to get the Withings data into Garmin Connect:
    - create a myfitnesspal account
    - connect withings and myfitnesspal together
    - connect myfitnesspal and Garmin Connect together
    So Withings will talk to myfitnesspal and then myfitnespal will talk to Garmin :-) Works fine for me!
    Yes worked for me too. But I am hoping ios8 health app will make it even easier from launch on. As long as withings, garmin etc all make use of the API.
