depuis quelques jour lors que j'exporte mes activité en gpx, le fichier généré est quasi vide avec le nom activity_o, ce fichier est inexploitable. même chose avec tcx et fit
Could you post a link to one of such activities?
Open the activity in Garmin Connect Web, make it visible to Everyone (see the padlock icon in the top right corner of the page), and post here the URL from…
I was able to export the GPX track without problems, although I had to save it as Course, and then export the course, since everyone can export directly only their own activities. There does not seem to…
Could you post the zipped fit file, taken from the watch, here? Please use the Insert Video/Image/File » Upload function for that. If possible upload the file of the same activity as the link you posted…
OK, I imported the activity all right, and can confirm that exporting it as GPX or TCX results in a file containing just an almost empty XML envelope. Changing the activity type does not help either. Looks like a bug on Garmin's side. I recommend reaching out to the Product Support through their website at https://support.garmin.com.
However, I am able to export the activity in the original FIT format (it is the first option "export file"), and as well I am able to save it as Course, and then export the GPX file from the Courses page. So if you need just the GPX track, without the heart rate data, that is the way to go.
thank you very much for your help
what do you call the courses page ? and what is for you "save as a course" ?, i don't understand this , as i use french version of connect
i tried to change the activity type as course , same result ko when i export in gpx
I have also found a workarround solution :export activity as fit file and then use a web converter solution likes https://www.alltrails.com/fr/converter.
It's working (only track) but if your solution is quick ; i take it.
I try to open a ticket at support garmin, but the chat isn't working (the pop up window disappears) and i 'am not confortable for call with my poor english
thank again
There is a local support in almost every country, France including. So the staff speaks French.
Thank a lot again and sorry for lack of understanding
After exporting activity as course, when i open the course page, i see the course but the only possibility that i have is to export this file on the watch , as this file is comming initialy from the watch as activity , i don't see the point except if can copy the file in gpx format after synchronize with the watch ?. But in this case , where is located this file on the watch directory, i can't find it.
You right, i have found a garmin french support, so i with open ticket with them.
Thank again
