In the last days the forum seems to be have some problems, so perhaps we could try to collect some data from people experiencing them, and also to post some available workarounds.
So far, I know about the following problems, and have experienced all of them too. The suggested workarounds sometimes work, but it is not a rule, so you may need testing more alternatives:
- Access to the forum blocked, with an error message from CloudFlare
- Deleting cookies for garmin.com and cloudflare.com
- Using a different browser (i.e. Firefox)
- Using Incognito Mode
- Impossible to submit a reply to a post. Usually it happens when the reply contains one or more of the following items:
- Embedded image or file
Workaround:- Hover over the pasted image in the message body, and in the menu that appears, select "Convert to Link"
- Post a link to an external storage instead (may not work either - see the next item "Hyperlink")
- Post without the image, then edit, and try adding the image then
- Try replying to a different comment - i.e. the OP instead of the last post, or vice versa
- Remove the image from the post
- Hyperlink
Workaround:- Click the link, press Ctrl-K, and remove the "Text to Display"/ Simple link without the alternative text usually passes all right
- Remove the hyperlink
- Post the link as plain text (remove the leading https:// and paste it in plain-text mode with Ctrl+***+V)
- Try adding the link later after editing your original post
- Quote
Workaround- Remove the quote and just copy and paste it instead of using the built-in quoting feature (you can use Format » Formats » Blocks » Blockquote for making it look alike)
- Use Tools Source Code and remove the hyperlink from the code
- Try adding the quote later after editing your original post
- Special characters - in some cases some simple characters like the parenthesis, double or simple quotes, or even a question mark may prevent you from submitting the reply
Workaround:- Unfortunately you will have to experiment which of the characters causes the trouble, and remove it.
- Sometimes copying the entire text and pasting it back as simple text (Ctrl+Shift+V) helps
- Often, you can use another similar character instead. There are many Unicode characters that look similarly, and can replace the original. For example ⁇,
, ¿ for the question mark, ´ for the apostrophe, [ ] instead of parenthesis, «» for double quotes, but there are many other alternatives as well.
