Requirements:
- own workout with weights set and one bodyweight exercise in the middle
- count reps turned on (because without reps you are not asked for weight even if "edit weight" is on)
- edit weight turned on
Bug1: When ignoring the rep counter (because it counted correctly) it will record weight 0 in the activity.
If I enter the "edit reps" screen and go through to the "edit weight" screen it will preselect the weight set in the training to edit or confirm.
Also if "edit weight" is off the pre-planned weight is always recorded in the activity correctly, no matter if reps are adjusted or ignored.
Bug2: If a bodyweight exercise follows a weight exercise it will show the weight of the previous weight exercise instead of 0 as it should be. And it will be 0 in the stored activity if the rep counter is skipped.
If "edit weight" is off in will always record the correct weight preset in the activity no matter if its 0 for bodyweight or a larger value for a weight exercise.
Is this reproduceable on devices like Fenix 6, 7, Epix 2, Forerunner 955?
