I have not received the trick or treat badge so I can not share it to get share the scare badge
Whatever, they should fix it, people see the Trick or Trick badge for ages and prepare themselves to get it. So the best would be if they fix it by awarding it to whoever made an activity in 2022 + make…
This year there is only one Halloween badge: Halloween 2022
The others are moved back to 2021. Garmin made a mistake when they moved back the dates and forgot to set an end date wich makes them visible…
I wrote this reply in another thread about the same issue:
The others are moved back to 2021. Garmin made a mistake when they moved back the…
Seems to been disappeared from https://garminbadges.com/ so don't keep your hopes up... Yeah, I didn't get it either (2021 yes, 2022 no), sniffels
The start and end dates control when the badge is visible for the users. Every year Garmin moves those dates to the next year. They first moved them to 2022 with correct start and end dates, but a few days ago they moved them back to 2021 but set the end date to null.
They are visible as available, but you will not get them. There has been a few reports of people getting them, but no description of how they did it. I've done multiple tests and there are many discussions about why they don't get the badges even if they are visible as available.
I shared it from the mobile app following the instructions but did not receive the "share the scare" badge.
Hi, yes got that one, but not the trick or treat 1 so couldn’t share to get the share the scare 1
