Hello all,
Before the Garmin outage, I imported the garmin callendar to iCloud, and it worked perfectly.
Now nothing appears on iCloud calendar.
I deleted, added new url, but still the same.
Any hints?
It's not working for Google Calendar either. There aren't any solutions yet
I had this working before the outage as well, on my iphone and another calendar script.
I think I know what the issue is:
In the ICS the EVENTS for Workouts do not have DTSTART... Which is the date which…
Same problem here. The ical file format connected to the URL appears to be a problem. Garmin - Please fix this.
Answer from Garmin-Support (translated from German):
The problem you describe is already known and is being worked on by the developers. Unfortunately, they have not yet found a solution to fix the bug. But we assume that a solution will be offered via an update. Therefore we ask you for your patience and thank you for your understanding.
Also working for me now.
I had a problem logged with Garmin and just received the following:
"We're reaching back out regarding reports of an issue with scheduled workouts not being displayed in third party Calendars when subscribing to the URL generated in Connect. This issue has been resolved via a back-end update and we are no longer able to reproduce the issue."
