Badge Challenge August Weekend 40K not being awarded August 30th
I did a 50 km bike ride today Sunday August 30th and wasn't awarded with the badge "August Weekend 40K". I did a test and moved the ride to yesterday (August 29th) and got the badge right away. I then moved the ride back to today (August 30th) and the badge was removed.
The description of the badge challenge:
"Join this challenge and record a 40-kilometer cycling activity from August 28-30."
The start and end dates for the badge are: 2020-08-28 00:00:00 and 2020-08-30 23:59:59
https://connect.garmin.com/modern/proxy/badge-service/badge/detail/v2/1203
I can only come to the conclusion that the dates are incorrectly set somewhere in the backend so that the system doesn't award the badge today.
There are currently some issues with Garmin Connect so I can't continue to test, but when it works again I will test if I get the badge if I move the ride to Thursday.
    0 Former Member in reply to seilogramp
    Yes, for lack of better.
    Thank you for your reply.
    0 Former Member in reply to trux
    The problem is that only in watch.
    I use Garmin Connect via web and in phone - training didn't synchronize with Garmin Connect on phone so I can't edit anything. Normally I've got information thaht training is ready in app (since now I don't have thaht info about this one training,  despite this, the minutes of intense activity have been counted). My cycling from yesterday synchronized fast as normally.
    The second problem is that my computer doesn't reconize my watch so i can't put this training manually.
  • My cycling from yesterday synchronized fast as normally.
    I am afraid I do not understand at all what you mean. If the cycling activity synchronized to Garmin Connect normally, then what prevents you from editing it?
    Not sure what you mean by your computer not recognizing your watch, but if the activity was already syncronized normally through the phone, as you wrote, then the activity is available in Garmin Connect Web in the same way as it is in Garmin Connect Mobile (they are just two different interfaces to the same data). You do not need connecting the watch to the computer.
    If you have problems with syncing your activities or other data to the Garmin Connect account, then read the following post: forums.garmin.com/.../1115488
