Corrupt FIT File Repair Requests
Hi,
I would like to load this file into any software, but all of them tell me that it cannot be imported.
For some reason the file is not working (the watch ran out of battery while it was tracking the hike), but I would really like to have it.
Any ideas?
Thanks.
Top Replies
All Replies
    hi Suzie,
    Give this file a try.
    cheers
    Mike
    hi Suzie,
    cheers
    Mike
    thank you Mike
    it's much better than before but I can't see the swim and T1.
    for the bike it looks to long, it should be around 20km but the time, the laps and the gps track look good.
  • Well, I'm back again with a long-run that won't sync. Can someone please help with this file? Thanks you kindly :)
    hi Jerome,
    The data for the remainder of your run just isn't there for me to manipulate so there isn't a lot that can be done.
    The laps in the run part of the data track nicely from 13 thru to 18 and then leap to single data record during lap 23.
    FFRT also reported that the recording ended suddenly - was there enough room on your device to record the entire triathlon?
    cheers
    Mike
    Thanks Mike for your time and your answer.
    hi well.executed,
    Give this file a try. One corrupt time record was the cause of your issue.
    cheers
    Mike
    hi Suzie,
    Before you upload this file, ensure you delete any previous versions from Garmin Connect. Should then work like a charm.
    cheers
    Mike
  • Thank you so much @kiwimtnbkr! This is such a great help, and I am thankful for it.
    Hi Mike,
    thanks for trying. Do you know why my garmin is doing this more and more often? I would like to prevent this to happens
    thanks for your help!
    hi mepotvin,
    How many completed and uploaded activities are still on your device? If it's any more than a months worth then it's time to archive them off to a folder on your computer or delete them. Recording an 800kb activity file doesn't work when there is, for example, only 700kb of available storage space.
    cheers
    Mike
    hi Suzie,
    cheers
    Mike
    Thank you so much, it's perfect now.
