Corrupt FIT File Repair Requests
Hi,
I would like to load this file into any software, but all of them tell me that it cannot be imported.
For some reason the file is not working (the watch ran out of battery while it was tracking the hike), but I would really like to have it.
Any ideas?
Thanks.
Top Replies
All Replies
  • hi Paolo.Uitko,
    I can't get the file to load into the Fit File Repair Tool - it keeps coming up as corrupt.
    cheers
    Mike
    Yep I know, this was the file in my "activities" folder. I had the same problem.
    Downloading from garmin connect it gives me this file maybe it can be used?
    Thanks a lot
    Paolo
    hi Pete,
    Give this file a try - it should now work. It appears to be something with the developer data that was upsetting it so I've excluded it during the export.
    cheers
    Mike
    hi Paolo,
    There is a gap between 00:00:22sec and 5h15min in your ride data - I'm not sure if there is meant to be data there or if your Garmin has done something strange.
    I've stripped off the first 22seconds of data so give this file a try.
    cheers
    Mike
  • Mike,
    thats marvellous, thank you very much.
  • hi Paolo,
    cheers
    Mike
    Thank you for your time spended on try to fixing, but this is only the second part...I will try to not power off my garmin on next long pauses to save battery. :(
    Thanks again...
    Hi,
    I finally beat my Parkrun PB after more than two years trying! Unfortunately my tired brain pressed the wrong button and I deleted the record instead of saving it. I recovered it from the deleted file on the watch and renamed it back to what it should be. I am not able to access it using the online file converter tools as it was never properly saved and so just throws up errors.
    Any chance it can be repaired?
    Thanks.
    What should the run distance be?
    cheers
    Mike
    5 km or thereabouts.
    Thanks Mike
  • Can someone please help me with this file? I am on tour so can not access a pc to use the software myself.
  • Psi164,
    Give this file a go :)
    Bart
