Corrupt FIT File Repair Requests
Hi,
I would like to load this file into any software, but all of them tell me that it cannot be imported.
For some reason the file is not working (the watch ran out of battery while it was tracking the hike), but I would really like to have it.
Any ideas?
Thanks.
Top Replies
All Replies
    hi Sepie,
    I've been able to upload the file to both my GC and Strava accounts. You have deleted the file from GC or Strava if you have previously uploaded it? Have you tried doing it as a manual upload?
    cheers
    Mike
  • Mike,
    I am able to upload the file to both GC and Strava using the manual upload feature which requires me to locate the corrected fit file. The issue isn't that the fit isn't recognized but that the GPS data is missing. The route was 15.3 miles but when I load the fit file to GC or Strava, it's listed at 0.8 miles in total distance.
    Uploading to Strava yields the same results as shown below. Are there any other steps that can be taken to correct the file?
    Best,
    Sepie Moinipanahciq.forums.garmin.com/.../1294924.png
    hi Sepie,
    As I noted in my original post, the corrupt file only contained 0.8miles worth of data. The remainder of the data just isn't there for me to correct.
    cheers
    Mike
  • Hi, is it possible to import .fit files such as the attached one to Garmin Connect? It was generated by the Concept2 indoor rower logbook (log.concept2.com), it's accepted by Strava and Training Peaks, and Endomondo, contains all data, but GC won't recognize it (An error occurred with your upload. Please try again). I used to sync Strava to Garmin Connect via tapiriik.com, but the service has stopped working for me recently. Thanks a lot
    hi Oleksiy,
    I imported the file in the File File Repair Tool and then used the export function to upload the file to Garmin Connect, which it successfully achieved. FFRT must be changing something in the file structure but as to what I am not sure.
    So the answer to your question is , Yes, it is possible to import Concept2 indoor rower logbook .fit files into GC BUT only after the structure has been fixed with a tool like FFRT.
    Here is the 'fixed' file.
    cheers
    Mike
  • Thanks Mike, worked like a charm, now contains even more data than in files imported from Strava via tapiriik. Will consider buying the FFRT in case I don't find a cheaper solution. This tool is way too expensive for my use.
    hi, today I accidentally deleted a recording on my Forerunner 235. Luckily I managed to undelete the file on my PC, but it seems to be corrupt. Can anybody help me fix the FIT-file? Thanks in advance!
  • Hi Mike,
    I'm hoping you can help me as you've helped others. I did an Ironman race and the data is no longer loading: https://connect.garmin.com/modern/activity/2011173723 I know it was loading shortly after the race but recently went back to look and it won't load. I was able to pull the FIT file off my watch but when I try to manually import it fails. Is it possible for you to see if something is wrong with the file? It's too large to upload but I've shared it here: https://drive.google.com/open?id=10kq_p9o6D7kFAopYkGo3uts_GAnrmKUy
    Thanks,
    -Chris
    hi Garthman,
    You had a small amount of corrupted data at the end of the file - not sure how much data you have lost but it shouldn't have been a lot.
    Give this file a try.
    cheers
    Mike
    hi Chris,
    I am 'tentatively' going to say that it is Garmin Connect issue as I have been able to upload the file to Strava without any issues. But like you, I was getting an upload error with GC.
    Couple of days will tell....
    cheers
    Mike
