Corrupt fit-file? How to fix?
Hi there!
My device is syncing, but my latest activity does not show up in GC. Manual upload to the activity-list stucks without error message.
What app do I have to use to open file? Any ideas to get this fixed are welcome! :-D
  • My treasured Vivoactive HR is dying a slow death :( with increasingly frequent shutdowns and other glitches. Two such incidents resulted in corrupt .FIT files - would very much appreciate it if I could get these fixed.
    Thanks in advance!
    P.S. When I tried garmin.kiesewetter.nl it just seemed to hang - is that site broken or was I just too impatient?
    hi ramjam,
    Give this file and this file a try.
    Would also suggest trying a factory reset of your device and seeing if that helps - especially seen as it looks like you've done a firmware update recently.
    cheers
    Mike
    Just tried to upload my latest activity and getting this message: "The upload appears to be malformed and we are unable to process it" Please can you help fix it? thanks
    hi Steven,
    Give this file a try.
    cheers
    Mike
    Thanks Mike!
  • hi ramjam,
    cheers
    Mike
    Thanks, Mike, the fixed files worked great! The factory reset, unfortunately, did not. I'm pretty sure it's a hardware issue - in addition to the random shutdowns, the upper third of the touchscreen no longer works, which means certain key screen buttons are unpressable. Wishing now that I didn't try the reset, because the touchscreen issue prevents me from setting the watch up like I had it.
    Mike, could you please help me with the attached invalid .fit file?
    Thank you!
    hi alyshu,
    cheers
    Mike
    Try this one.
    I couldn't get this to work, the file type wasn't recognised ????
  • jacko1747 it's working for me. Says "Borders Cycling." Did you unzip it? Here it is unzipped.
