Manual Import for tcx not working--FIXED!
I haven't been able to import .tcx files for the last two days. The files were created by Trainerroad, everything worked alright before that.
I already talked to Trainerroad and they didn't change anything in the last few days.
Is Garmin currently working on the import function?
  • Same issues for me with the upload. It says complete but the files don't show up. I was able to sync some files by using Tapiriik, but not all.
    I uploaded two files that I cannot add to Garmin Connect into the One Drive.
    Garmin also wrote me a mail, I sent them the files and described the issue. Let's see how this plays out :-).
    Cheers
  • I'm having the same issue, since Wednesday. I did a file on Tuesday that worked.
    Doing the Import Data option from the website, selecting a .tcx file, and it says it's uploaded, but does not appear in my Activities List. I've been doing manual tcx uploads for about 3-4 years (very old wattbike that does not support Garmin, so I use www.wattbike2garmin.com to generate a .tcx file).
    It _is_ syncing to Strava, however (I have my Connect Account and Strava linked), so it must be getting uploaded at least...
  • Yep, like BABYCHAOS, some manual .tcx files I am uploading are not showing up in the Activities list but clearly are being uploaded to GC as they are being pushed over Strava.
  • Do you need another txc file to test? I have my train from yesterday @TrainerRoad ready to upload to the OneDrive Folder if you need more files to test.
  • No import tcx from wahoo.
    Same here.
    I have 2 accounts using wahoo tickr export through, mail import GC problem since 9march.
    When complete, click on view details, blank page then start of activity list.
    Normally when I select view details I go to activity itself.
    Importing a fit file appears to be OK.
  • No but you can continue to use this a central repository in case anyone else wants to analyze the files. I assume these typically have no GPS data?
    Correct, no GPS data (at least on TrainerRoad files).
  • Same issue with manually importing .tcx files from TrainerRoad
    Just a note to say that I am having exactly the same issue as described above. I normally manually import TrainerRoad .tcx files to my GC account. For the last two days the import appears to be successful but when I click view details it brings me to the activity page with no file.
  • Sundays LANE
    You are right. I've uploaded a .tcx without GPS that I was able to add to Garmin Connect on Wednesday for comparison.
    My files include:
    * HR
    * Cadence
    * Speed
    * Power
    Cheers
  • You can upload to my shared OneDrive folder.
    I have uploaded two files they start with mgaccioli...
    Thanks,
    Mike
    [email][email protected][/email]
    Thank you for the continued discussion on this top and for posting the TCX files. This is an issue that we are working with the Connect team to investigate.
