I have tried to connect myfitnesspal to a couple of times now but weight won't sync. No matter what i try.
@Gamrin, please fix this or read weight data from the ios health app. Should be trivial to…
After some failures i managed to find not a clean way to sync weight from Xiaomi Mi Smart Scale to Garmin connect
Xiaomi Mi Boody Composition Scale adds weight to Mi Fit app >
Mi Fit app is synced…
Hi guys I'm the author of the Mi Scale Exporter. I'm happy to see that it works well (in most of scenarios) and thanks for all the feedback.
Originally the app was for my own purpose, so it is…
I have tried to connect myfitnesspal to Garmin a couple of times now but weight won't sync. No matter what i try.
@Gamrin, please fix this or read weight data from the ios health app. Should be trivial to implement!
Really do not appreciate being forced into buying a Garmin scale. In the long run that will be a losing proposition... I do not mind leaving the garmin eco system for a more open one.... Plenty of alternatives out there.
Same problem. One solution is typing all data manualy by apk called Weight Logger. Tested and working. Or maybe I hlave another solution but I need help. I have data from my scale in cvs format from download link posted via email from huami. I was surprised because this file is simple text fille. In GC there is an option to import data, but this one is not Fitbit one, so import process failed. Is there another way how to put my data to GS
Same problem. One solution is typing all data manualy by apk called Weight Logger and then export data directly to GS. Nôt only weight. Tested and working. Or maybe I have another solution but I need help. I have data from my scale in cvs format from download link posted via email from huami. I was surprised because this file is simple text fille. In GC there is an option to import data, but this one is not Fitbit one, so import process failed. Is there another way how to put my data to GS
