Calendar publishes only events and workouts
I want to publish my Garmin Connect calendar so I can import it to my Calendar app on my laptop or/and to my Google Calendar. The calendar is imported successfully but unfortunately only "events" and "workouts" are published. None of my "goals" or "activities" are visible... Is there something else I have to do to publish them? Is this supported at all?
  • Last time i looked into this Problem is now 8 (!) years ago.
    Well, if nobody used the form at Submitting an Idea to Garmin for suggesting it to Garmin, then it is not likely to change in the next 8 years either. Only if there is a high demand for such functionality, it has any chance to get implemented.
  • BTW, I did not test it, but the document Publishing the Calendar or Connecting with Office 365 in Garmin Connect tells the following:
    « Activities, workouts, and events from the past 30 days will be synced to Office 365 once you are connected. After connecting, any new activities, workouts, and events will continue to sync to Office 365. »
    It means, you can use the Office 365 Calendar and export it to your Google Calendar from there. You can also try temporarily setting the date on your PC or phone to a past date, to see whether it then exports also Activities older than 30 days. This trick works with some other features of GC, so there is a chance it could help here too.
