Workouts cannot be saved in GC
Whenever I try to edit and save one of my workouts I get an error. It states "The workout could not be saved because of a system error. Please try again later." This is happening since last Sunday!
    I am getting an error message trying to save a new workout. I don't have any workouts yet, so don't know if it is possible to edit. But bit frustrating not to be able to test the workout function.
    I've only recently tried using workouts and same as everyone else here, I get the error message "The workout could not be saved because of a system error. Please try again later." every time I try to save a workout.
    Anyone heard back from Garmin?
    Thanks
  • Yep, same goes here...
    Hi guys.
    I've been facing the same issue from beginning of February. I expected that it might be just temporarily, as it had already happen many times, but still after almost two month there's no solution to the problem.
    I've also tried anything - saving a new running workout, updating and old one, deleting some of the old ones (supposing that there might be a limit of the number of workouts you could store, and that causing the problem), but without ANY effect. It still says "The workout could not be saved because of a system error. Please try again later."
    Last night I saw some old solutions to the problem - to install Training Centre, and I did so, created a profile, defined user settings and etc... and found out that the software cannot find my device (FR 310XT). I know that the device is some times refusing to connect/synchronise, so I checked it with Garmin Express and the app I'm using on my phone - both worked flawlessly. Then I decided (after Googling the problem) that the training centre is maybe lacking the communication plugin - so I found ant+ agent, installed it and yes - it was not working... maybe because it's incompatible with 64b W7, or it's incompatible with Garmin Express, frankly - I don't care. I got really pissed off (actually I still am) and stopped that before breaking anything.
    So, I'd just like to know if anyone tried to raise the issue to garmin support and if you had any response, so I don't lose my nerves on the same thing again.
    Thank you in advance.
    Regards,
    Veselin.
  • The workout could not be saved because of a system error. Please try again later.
    Hi
    I am also getting the same message. Did you ever get it sorted?
  • Me too. Please fix Mr Garmin.
