I am half way through a 10k Garmin coach plan and the pace I need to run between has always been visible when I look at the workout. Today it has just disappeared and I can seen no pace for any future runs.
Thank you for this report. To investigate further please respond to the following:
We're following up on the report we received that when viewing your workouts in your Connect app that had pace, cadence, or power ranges, the workouts' targets showed as blank or just 0. We're pleased…
We have enough reports of this at this time. The engineering ticket is being worked and I will notify you all with an update when the fix is available. Thank you.
I just updated to Version 4.69.1.5. Seems to have fixed the issue.
Me too
How about an update on this? The communication from Garmin on this issue has been very poor.
I just saw your post. Can’t believe they’re so bad at communicating as it’s a big frustration. You can see your pace targets on your watch if you accept the run and view the activity beforehand. Also, you can log in to the online Garmin Connect web app and your pace should be there too.
Not sure why someone from actual GARMIN wouldn’t have tried to communicate this and be proactive to their “valued” customers…….
”Beat Yesterday” isn’t so hard if you’re not doing much - come on Garmin. Be better.
Thanks for the tip to use Garmin Connect online to create new workouts! It does appear the pace is updating correctly if you create them online and skip using the app. I agree I can’t believe how poorly Garmin has handled this. It is clearly impacting everyone that is using version 4.69 and they have been silent for days.
