Can I remove the Hydration shortcut and replace it with a BP shortcut? I have never used or entered hydration data but track my Blood Pressure daily…
Ah, OK, I misread your original post - for some reason I saw "I do not have the Index BPM". Well, it is a bit paradoxical that you need the device for being able to enter the BP manually. It…
A solution might be borrowing the Index BPM from someone, or doing a test purchase, adding it to GC and then returning - you'd keep the possibility to enter the BP manually
Just change the country to USA in your Garmin Profile at https://www.garmin.com/account/profile/ - it works fine, tested.
I don't have the Index and am able to manually enter my BP readings in Connect on iOS and Web
Interesting. Which watch (and accessories) do you have registered in your Garmin Connect account?
Forerunner 955 and HRM-Pro Plus
Apparently not available outside of the US.at this time.
Spoken to support. Currently only available in the US. Hopefully will come to the UK soon
Maybe try a VPN, if this is important?
