I finished a run this morning & pressed the stop button but forgot to press save on my Garmin 45.
Run not recorded but can I get it back ?
Then there is a chance it is still on your device.
I have no experience with successfully fixing a golf activity. Might need someone else to assist. Meanwhile, I suggest at least reporting this issue to Garmin Product Support.
You might need to try a file recovery tool such as mentioned here - how do I get my activity back if I delete it?
Just know that even after recovering it will be corrupt and need to be repaired.
I have same problem
Follow the hints from the previous post of seilogramp or simply run again
Did you try a recovery tool as advised by seilogramp? If the recovery tool did not find any deleted file, then you can only add the activity manually (or run again).
My advice is to record a short run, then editing it and adjusting the distance so that it reflects also the distance from the lost activity. You will not have the map, and all the other metrics, but at least you will have the distance.
