Sending Workouts/Training Plans to devices (started happening recently)
It used to work fine, for a long time, but now I cannot send structured workouts to 935 anymore. GC Mobile and 935 find each other and synchronize, but GC Mobile cannot send neither a structured workout nor the calendar with workouts. I tried starting the sync from the 935, using wifi our bluetooth; in both cases it syncs, "transfers" and "updates", but the workouts do not appear in 935.
The only way to send a structured workout is to connect the 935 using the USB cable and then send it using Garmin express, which is cumbersome.
I already tried the normal things such as switching on and off the 935, Garmin Connect Mobile, and unpairing the 935 from the phone and adding the 935 just after. I also cleaned all history so that memory isn't a problem.
It may be a coincidence, but apparently this problem started after the 935 software was upgraded to v12.
Thanks.
  • Oh so quiet from Garmin on this Issue - why ???
    I believe the idea being the watch software causing the issue to be true and not the android app.
    This worked for me, I had issues sending training plans to my device!! Let me know how u go!!
    • Connect the device to the computer
    • Open the device as a mass storage device
    • Open the Garmin folder
    • Delete the workouts folder
    • Empty the Trash (if using a Mac)
    • Safely disconnect from the computer
    • Then resend calander via Garmin connect
    Yes, this successfully solved the problem. Thank you ever so much.
  • This worked for me, I had issues sending training plans to my device!! Let me know how u go!!
    Didn't work for me... :-(
  • I had the same issue last fall with my F5. Then I was able to send the end of a training plan (without doing anything special) thru Garmin Express.
    Yesterday I connected the watch to the computer, I gave it a try, it worked for the 5 sessions left that were on the calendar. So I spent some times on the computer in order to add the 3 month-training program beginning in march : it no longer works.
    It's not a matter of size as I've done it before.
    Garmin will do nothing about it, and the process to delete the workout folder didnt make it.
    Does not work for me
  • Garmin Garmin-Joey Up ! Still no news. Support said working on the issue near than two month ago
  • This still doesn't work. I'm on Garmin 12.5 and iOS 12.1.4. Would love to use one of these training programs but it's pointless.
