Forerunner 920XT issues - GCM hanging and Re-pairing required with pin
Hi guys
Hopefully support read this forum so it is a useful post and also to hear from others with similar problems
My setup
GCM 2.5.2
FR920XT (firmware 2.5)
Android 4.4.4
Sony Xperia Z1 Compact
Issue #1 sync hang
Had a lot of hanging when the forerunner is syncing.. in the image you see that the sync is hanging half way through. Once it hangs nothing to do but try and crash it (usually by turning off bluetooth on phone)
I think I have found a work around (think).. which is to leave GCM using the back buttons (repeated until it takes me back to the home screen) rather than use the home screen button.
Issue #2 re-pairing with pin
This is the real biggy
Several times a day I go out of range of the phone. When I do the connection is lost and the only way I can get it to re-establish the connection is through re-pairing using the pin.
If it was a 'click here to reconnect' button it would be fine.. but the whole thing means I need to ..
a. pull down the notifications bar from the top and click on the Yes to connect request (when the phone spots a request)
b. pull down the notification bar from the top again and this time go through the re-pairing process by entering the pin showing on the watch.
It is seriously taking away from my 920XT experience
Things to note
1. I am a long term Garmin user and have used GCM/bluetooth with my Edge 810, Vivofit and FR620 (the 620 could be fussy and not always connect, but usually worked)
2. I have tried the usual..
  • Turn on turn off Bluetooth
  • Turn on turn off phone
  • Remove device and re-pair
  • Uninstall and reinstall GCM
Would love to hear if this is a known issue that others are experiencing and if Garmin are working on some fix
To garmin.. really don't mind being a tester.. been with you guys since the FR301 :-)
    0 Former Member over 10 years ago
    Glad to report that since installing 3.2 the other day on my 920xt my bluetooth pairing issues have disappeared. My Sony Z3 compact now picks up my 920xt when I come back into range. I had to repair my watch when I upgraded and it would only work via the GCM app. But so far very happy not to have to repair on a daily basis.
    Sorry, what Android version on your Z3C? I have version LP 5.0.2 (23.1.A.1.28) - I can not even pair my Z3C phone and 920XT. 920XT has 3.30 version.
