Forerunner 745. The Heart rate l did set for running is ignored during running. In fact after the activity the heart rate zones recorded do not match with the ones l set. Why?
and now I got also another issue: in the attempt to fix the problem, I I unpaired(deleted) my FR 745 , then add again. After this operation the planned activities in the calendar App cannot be opened. For instance, if I click in the activity planned for tomorrow, a window with today activity is opened. Situation became worst and confused.
That's a bug in the current version of the app. Either use the web app, or uninstall it, and install an older version from an unofficial APK archive such as the apkssl.com or apkmirror.com. Or just wait till the next GCM release, and hope it will be fixed.
The Activity shows you are using the HRM-Pro - aren't there independent HR Zone tables in the Device Settings of the HRM? That could be the reason of the difference.
Another possibility is that you have the auto-detect option enabled at the LT or at the Max HR, changing so the zone table dynamically to reflect the real-time LT and HRmax values.
I cannot se any settings I can do in the HRM-Pro. Anyway now is not with me so not connected, So I will double check later.
Regarding " auto-detect option enabled at the LT or at the Max HR " I try with all available option, LT settings , then with %, but never matches my manual settings. In any case I put my LT showed in the app 149 Bpm, but anyway does not match with zone 4. But it should be there.
I have a Forerunner 955 solar and the zones displayed in both Garmin Connect Android in my run overview are not the ones I have set. I checked and double checked and the HR-zones on Garmin Connect and my 955 for running are correct and the same.
For example my Z3 is set to 133 - 139
in the overview on Garmin connect with the run stats Z4 shows 116 - 139 (looking at time is Zones)
It looks like the set zones are not taken over in the results stats!
There are up to four different HR Zone tables - a general one, and optionally also one for Running, another one for Cycling, and yet another one for Swimming, so make sure you are looking at the right one. Besides that, if you use a HR Zone table based on the Max HR, or on the LTHR, and have also enabled the auto-detection of the Max HR resp. of the LTHR, then the HRZone will dynamically adjust to the last value detected.
Yes I double checked that I look at the Running table and I have disabled auto-detection so that can't be the issue. I believe that Garmin Connect (both web and app) doe not look at the actual set bpm-values for the zones but uses calculation based on the set LTHR
On the 955 I'm not even able to change the HR zones for Cycling
