Hello,
I couldn't find the Cadence Sensor 2 from list of device in Garmin Connect Mobile Android.
I've found only the Speed Sensor 2.
Somebody can help me with this?
BR,
Laurentiu.
Hello,
BR,
Laurentiu.
From the Garmin Support site:
The Cadence Sensor 2 can not be paired to the Garmin Connect app. To view and record data from that sensor you must pair it to a third-party app or compatible Garmin fitness…
I just bought a Cadence Sensor 2 online and feel like it was inferred that it could be read into Garmin Connect...but it isn't. What a joke.
cadence sensor 2 isn't availabe, you have to add them as ANT+ device on your cycle computer or watch and it only works, when you start an activity, thats normal!
How do you monitors cadence on the phone if you can't connect the cadence sensor from Garmin Connect? Others applications are working without a problem...:)
Hello, I have the same doubt. I have both speed and cadence sensor 2 but no Garmin watch or cycling computer yet. Which app are you using for logging? Thank you.
Cadence sensor 2 is also a Bluetooth device, from what I see in others applications: Urban Biker, Ride With GPS, Endomondo, etc. Why in Garmin Connect is not available?
i don't use them with other apps, but seems it could work with the above listed!
This is unfair from Garmin, they should have specified this in the product description or the garmin connect manual. I feel cheated after spending money. Garmin I hope you are listening.
Same issue here. not sure why that is. I would like to know the battery level of the cadence sensor, not only the speed sensor. It doesn't show up in my list either and I think its a bug Or maybe Garmin was cutting corners feeling its not nescessary to show both in the list? I have cadence information. It always pairs fine. Just doesn't show up in the list of garmin devices for the cycling activity. very strange.
The Cadence Sensor 2 can not be paired to the Garmin Connect app. To view and record data from that sensor you must pair it to a third-party app or compatible Garmin fitness device.
https://support.garmin.com/en-US/?faq=lIHN1t3sLK02hr9jl36kyA&productID=641212&tab=topics&topFaq=true
