My "Save" button in Connect IQ Data Fields settings is doing nothing. Is dead.
What can I do? Thanks.
Garmin, are you still with us? The problem still exists, although there were several updates. It's really annoying that I have to plug my watch to the PC and use Express to change settings.
The odd part is it just started...Was happily using 2.15 for sometime and then it just began on that version. and previous versions back to 2.11 and ANY new version... SO what did garmin do??? That s the…
FIrstly if I said what I want to say to the response I would get banned..
As to which version of IQ the current version(2.15) as of todays day and up until a yesterday was working fine than just stopped syncing settings and the same issue happen with the connect app.. Both will allow new apps etc to install and uninstall but both will not save and settings you try to apply to the app/watchface etc.... And as it has been reported several times by other forum users this is not an isolated issue..
What is now even stranger... IQ and QCM both have updated for me today. I can install NEW apps etc and change the settings + save them fine. Yet and previous/currently installed apps etc I can't!! Even if I uninstall and reinstall I still can't change the settings for apps etc I have already installed!! Figure that one out because it has confused the HELL out of me!!!
OK so this keeps getting stranger I can install any app BUT I can only change settings for GARMIN MADE APPS/WIDGETS ETC!!!!!!!!!!!!!! Yep you ready that correctly If it is may by garmin changing and saving settings works perfectly in the Phone apps. But ANYONE else's this issues noted above continues.
So that to me is a confiramtion the issue is GARMIN and not user.... Thank you for confirming this....... But what I do not understand is why one day it was working and the next it just started with the issue... And the phone apps had not been updated in weeks!!
PS rolling back to v4.48 did indeed FIX the issue...So THANK YOU for that tip...
PS CIQ 2.11 works fine too if you downgrade to that version
Yes, that's really strange. The problems started without an update before. So I'll continue with CM 4.48. I also tried CIQ 2.10 but it messed up my watch with an automatic update of a watchface that was an older version, so a downgrade. Since that CIQ was published I don't know why I should use it because CM has also the functions, too.
8 month later - bug is still there.
Android 10
Garmin 935
Clicking done while in settings doesn't do anything. Anything at all. Don't work for apps, data fields, everything
Downgraded Garmin Connect Mobile to 4.48, settings work. For the latest version (4.62) - it doesn't.
Unfortunately 4.48 has some other bugs while opening activities
I do not know what the problem is, but I can save the settings of CIQ apps without any problems, regardless the version of the GC IQ app. Try saving the settings with Garmin Express instead. If it does not help, and it concerns only some CIQ apps, then it may be also a problem of the concerned app(s). In such case, the best would be contacting the developer, and asking for help.
For me it is ANY CIQ app.... so thats not the issue..
As to the express idea... SERIOUSLY!!! the whole point of the phone apps is so you DON'T need a PC(but then that has only JUST started to actually let me access CIQ settings in the past few weeks after two years of always says server connection issues!!!!!!)
As to Connect and ConnectIQ If I want too change settings both have to be Connect 4.48 or Connect 2.11 or earlier to work... It is as frustrating as hell and doesn't matter is it is an android 8,9 or 12 device either same issue... and before you say report the issue... well 18 emails ;ater and no response,
