I have the VA3 Music and pair it with a set of Jaybird Run's and I'm constantly getting cut-outs where the music will stop, then play again like it's temporarily losing it's bluetooth connection. The problem, as I discovered, is that I wear my VA3 Music watch on my left wrist, and the bluetooth radio is located in the right earbud. If I hold my left arm up a little, the connection is fine, but when I'm swinging my arms back and forth as you do when running, the connection cuts out. Talk about a weak bluetooth radio!!!!! Does anyone else have this issue? I know it's got to be the VA3 bluetooth radio because this doesn't happen when I use my iphone or ipod nano.
Also, if I wear my VA3 on my right wrist, it plays fine. I think it's crazy that the BT radio in the VA3 Music can be that weak. Any thoughts, or do you think I have a bad VA3 Music and should return?
