Since the 21st of Feb the vo2 max estimations have stopped. Is this linked to the update earlier this week or is everybody else still getting the data?
I miss my vo2 max graph it been going up of late due to less weightlifting and more running.
This may provide some insight. I thought the VA3 would give a VO2 Max for walking, but it's not listed below. The soon to be released 645 is listed. To maintain 70% or higher for a 10 min span while walking, I would think one would have to be speed walking for some time or walking a steep incline.
Garmin FAQ Calculating a VO2 Max Estimate on a Garmin Fitness Device
VO2 Max Estimator on some GPS enabled fitness devices provides the estimated maximum capacity your body has to transport and use oxygen during an exercise. Increasing VO2 helps with your athletic performance. This value should increase as your fitness level improves and can be calculated independently for running and cycling.
Refer to your Owner's Manual to determine if your device is able to calculate a VO2 Max estimate for running and or cycling.
To generate a Running VO2 Max Estimate:Walking in most cases will not provide you with a VO2 Max estimate[SUP]1[/SUP].
- Activity must be recorded outdoors with a GPS signal
- Activity must be 10 minutes or longer in length
- Heart rate data is required
- Heart rate must be elevated to 70% of your maximum heart rate
To generate a Cycling VO2 Max Estimate:It is recommended that this be performed on an indoor trainer to eliminate variables such as elevation change, drafting, and pacing.
- Cycling activity must be 20 minutes in length or longer
- Heart Rate must be elevated to 70% of your maximum heart rate
- Power Meter is required
Note: The VO2 Max Estimate number represented is an estimate. The number can vary between runs and can seem somewhat erratic or inaccurate at first. These devices require a few activities to learn your performance.
[SUP]1[/SUP]The Forerunner 645 and 935 does have the ability to provide a Vo2 Max for walking.
