hi
anybody knows what is the cause of a click sound on right pedal on vector 3 ?i have it only when clipped in and pedalling or when side to side moving,not if i use trainers .can anything be done?
Clip your shoe into the pedal, then flip it over and see if you can move the shoe around to cause the clicking sound, and possibly identify where it is coming from.
Have a good look at the pedal body to see if any parts are loose or appear to be unscrewing.
Some shoes have a slightly different curvature of the sole where the cleats bolt on and that may be part of the issue you are experiencing. If you are having better results from using the LOOK cleats, then you can use those with the Vector 3 pedals.
