I am in Zone 17S [I know relative latitude has some to do with the added value of GLONASS ]
I am thinking maybe GPS only during walks, kayaking (SUP) [both with mostly open sky] and GPS+GLONASS during hikes [ravines, heavy tree cover] and just want to know what people are finding works best and if there is a huge difference in battery draw. Consider 8-10 hour hike before charges. I know GPS only is default and assume GPS/GLONASS is probably going to pull down more power.
Also whatever happened to using WAAS/EGNOS? It was designed to increase accuracy of GPS based on ground signals.
______________________________
Also, if i want to view a widget during an activity. Did I read right. HOLD the down button and then return to get back to data fields? I don't find in user manual for the 935 but do for Fenix 5/5S. FWIW can I use the Fenix user manual interchangeably?
