My Forerunner 30 watch stopped working on Sunday afternoon during a bicycle ride. The screen was totally frozen. I've tried a soft restart and then a hard reset, nothing worked. Each time I'm stuck on the Garmin screen with the triangle. I've tried pressing the 2 right hand buttons at the same time and then pressing the power button, nothing changed. Is the watch definitely dead or could I try something to save it? Thanks a lot!
Yes, unfortunately I tried it already
Update: I'm always stuck on the Garmin boot screen except if I unplug the watch from the USB cable and I let the battery die. At that moment, if the battery is completely empty, if I connect again the watch to the PC via the USB cable, the watch restart but in any case when I remove the USB cable the watch freezes again just after a period of time of 15 seconds - 1 minute :(
Yes it does show as a USB drive.
I had in mind that it could be an issue with too much activity files, so I removed all of them but it had no effect.
I just tried what you suggested but the watch still freezes less than 1 minute after the disconnection from the PC
Thanks anyway!
Thanks anyway!
Question: Is there a way to force the application of the last firmware (2.40) just to be sure that the issue is not due to a corrupted firmware? Of course, when I start Garmin Express on my PC and try to synchronize, it tells me that the watch has already the lastest firmware.
