Di2 synchroshift and Edge 520
On my Edge 820 I get a beep before a frontshift is made using synchroshift.
Now I'm helping someone set this up on an Edge 520. But I don't see the sounds option in the Di2 menu.
Is it possible to get the frontshift beep on the 520? The 520 has the 12.60 firmware loaded.
  • Bumping this because I’ve the same question and can’t seem to figure it out. Seems to work with the edge 1000 but not the 520. Any advice?
  • My 520 beeps with synchro-shift front changes. I also found out the other day that it beeps when you hit the 11th cog. Well, I’m pretty sure that was what it was. I was concentrating pretty hard on other things at the time.
    I’ve got other beeps turned off but the gear one still definitely happens. Works on 12.60, 12.80 and 12.90.
