Garmin 520 stuck on loading profiles screen
Hi,
I have seen a few threads on this and none of them are fixing my 520. I have been trying to reformat my Garmin to in essence "start from scratch" so far I have initially formatted on a mac, which I believe my have done some damage according to some other threads , since then I have used a PC and tried re-formatting in both FAT (default) and FAT 32, neither of which seem to work.
I have a copy of all the files from a friends "donor" 520, but no matter what I do it always hangs at the "loading profiles" screens with the 3 moving dots and I get no further, I have tried the following:
- Reformat and turn edge on to rebuild itself
- Reformat and copy across files from donor garmin (also running the WebUpdater and garmin connect syncs)
- Reformat and copy across the GarminDevice.xml file and run WebUpdater
I'm getting a bit frustrated, is there anything I am missing? Note none of the standard hard/master reset options work, I can only force to Mass storage, or get the edge into a testing mode.
Cheers.
