Setting wheel size in Edge 520 for indoor trainer. (2,025mm - not 2,096)
Hello to you, :)
I use an Edge 520 in the last couple of months and still have not managed to configure a wheel-size (circumference) in the speed sensor for indoor training. I need to define a circumference of 2,025 mm. not ~2,100 like in the road bike, speed is measured by GPS.
I do not have the wheel size config. option in my Edge 520. Garmin support have instructed me to do it via the Connect Ap. though I do not have the wheel size parameters for change there either.
I upgraded the SW to 3.6 in the Garmin Express on my computer yesterday, did all possible sinc's though the version of Garmon Connect on my mobile remained 3.5.. - if this matters.
Will appreciate your help on that :)
Thanks!
npr50
  • Do you have an external speed sensor?
    Yes - the one in the enclosed pic.
  • i have manual set my edge 520 i have sv 6.00 go to the speed sensor menu in your edge 520 and you will find it
    The sensor needs to be connected to the 520 in order to change the wheel size. With the sensor connected you will find the setting under sensor details in the menu.
  • To manually enter wheel size on an Edge 520, 1000, or Edge Explore 1000:
    Select Settings
    Select Sensors
    Select speed sensor
    Select Sensor Details
    Select Wheel Size
    Select Manual
    Enter in wheel size
    This wheel size will now be used to determine speed and distance values.
    Wheel Size Chart located here
    Thank you - Could you please
    - Could you please instruct me how to get the sensor connected ?
    I tried.. the 520 indicated that it's trying to connect but it did not work
    While *not* connected, of the below list, under sensor-details I do *not* have wheel related parameters
    Thanks again.
    Select Settings
    Select Sensors
    Select speed sensor
    Select Wheel Size
    Select Manual
    Enter in wheel size
    Got it connected and defined wheel size.
    Thanks for the help!
    npr50
    Thank you.
    Select Settings
    Select Sensors
    Select speed sensor
    Select Wheel Size
    Select Manual
    Enter in wheel size
    Thank you.
    npr50
