If I want to try and beat my own time, rather than either a friend or the KOM/QOM when using an Edge 520, I need to go through the tens of segments on my Edge, go to Strava -> Leaderboard -> PB. This is extremely tedious and takes a long time. Is it not possible to have a universal option so to speak that changes my Edge 520 to always compare my real-time segment performance against my PB?
To make matters worse, whenever I sync my device, it resets any segment I've changed back to the default leaderboard options so I must repeat the process each and every time I sync.
Anyone from Garmin able to confirm whether this is planned to be enhanced or are we stuck with this behaviour?
Great stuff otherwise - the only other improvement I can think of is to allow us to change which data fields overlap the segment map though this isn't too bad as we can still scroll up and down.
